#SERVER ERROR: Error while Compiling # FPGA
It seems like I can't compile my FPGA vi to the pci7831r anymore, I get the message "#SERVER ERROR:    Error while Compiling  #" when I try to do that. Is there anyone that knows anything about this problem. Recently i have also installed a 6259 Ni-daq device and I want to use it paralel with my FPGA device, could maybe this be the problem? I have attached two pictures of the messages I recieve when I try to compile my program.
Thanks in advance
/trajkan
(3,128 Views)
Here is a new message connected with the other one.
(3,124 Views)
Hello!
You can check out the things described in these posts:
http://forums.ni.com/ni/board/message?board.id=170&message.id=77249#M77249
http://forums.ni.com/ni/board/message?board.id=170&message.id=77549&requireLogin=False
Also note that it doesn't work on XP Home SP 2 (Xilinx compiler that it) but it works on XP Pro SP 2. If not anything of this work it might be worth re-installing the SW I am afraid.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,037 Views)
