03-11-2021 07:44 PM
Hi All,
im looking for some help on how to get NI MAX (NI VISA) to read the a SGA power supply using a RS232 cable, NI max reads the com but when i try to communicate to the SGA power supply i get :
i can talk to using the hyperterminal software so i now my cable works, i installed the required drives and NI VISA but nothing.
Thanks!
03-11-2021 09:01 PM
If a terminal emulator works it's most likely that you have not properly configured the VISA session settings correctly. It is common for DTE to expect a <CR LF> to know when a command is complete before processing the command and responding.
I don't know what an SGA is but I bet you a Kudos that the manual for the device tells you how to format a command properly.
