SI Notation in Scan Value and Scan from String issue
Units is only supported in Format to string, not in scan from string...
From the link:
{Unit} (optional) Overrides the original unit of a VI when you use a function to convert a physical quantity (a value with an associated unit). You must use a compatible unit. You can use this syntax element only with the Format Into String function.
Message 11 of 14
(1,207 Views)
Oh its even worse than that. Now that I have data in a CSV using SI the comma screws things up as well. Now I can't scan "10M, -3.1" even though I use the same format string for conversion and scanning. SI makes text very human friendly to read but now I have to build a special function to parse it? Sheese. What a PITA.
Message 12 of 14
(1,165 Views)
Hi Viper,
possible workaround in your own thread...
Message 13 of 14
(1,160 Views)
and Thanks to Dr Gray---
CAR 309897...R&D can fix it.
Nice find (Austin, we have a problem)
Message 14 of 14
(1,151 Views)
