SIMPLE SINE
Hello.
I would like to know how to do this operations in labview
I= (-0,541)(SIN wct) = -0,541sinwct
Q= (-1.351)(COS wcr)= -1.351coswct
I*Q=-0,541sinwct-1.351coswct
How can I create those sine and cosine... general....and obtain a result sucha as... -0,541sinwct???
(3,446 Views)
Again me:
For example if I change the sine and cos for x and y how can I graph those points afterwards??.
for example I would like to graph
-0,541x -1,307y... thats a point then another point
-1,307x+0,541y......this us anohter point
etc.. etc.. etc.. create diferent point and then graph them.
I dont want to unit the points with line... I would like to si like a vector coming from 0 each point... I want to create a constelation graph
(3,445 Views)
I'm not realy shure wat you want, but have you tried to use the fomelknop (little example attached)? If you have Matlab, just use the Matlab script knop.
(3,417 Views)
Hi Special K,
Could you please describe the program you would like to create? To give us a better view on what you exactly want.
When you want to create vectors you need at least 2 values for each input, so probably you should use arays.
Enclosed you will find an example of a XY Graph in combination with Array input.
Hope this will help you any further.
Peter S
(3,406 Views)
