SIMULATING HOME SURVEILLANCE SYSEM USING LABVIEW
hI,
Am working on a home surveillance system using a Labview and i was wondering how i can simulate most of the sensors without having them physically.The sensors include PIR, Camera and Magnetic door sensor.Also i must include the automatic lighting of once home.The system must be intergrated with Andorid phone as a controlling device.
(2,885 Views)
If you're integrating with a phone, you'll need to decide if you want this to be something you can access locally or from anywhere.
If from anywhere, you'll need to create a login of some sort.  You'll likely end up using web services to do that piece.  If you're only worried about locally, you can find a variety of ways to handle this such as data dashboard.
Simulating sensors is the easy part.  You know what values they can have.  You create a control.  You put values in the control.  Now, you have a simulated sensor.  When you get the actual sensor, you replace this control with the logic to read from the sensor.
(2,850 Views)
