SIT 5.0 error 14106
Hello:
When we execute the example sine wave.vi of the simulation interface 5.0 appears to us this error
Error 14106 occurred at Driver VI >> Error using ==> get_param
block_diagram does not have a parameter named 'InlineParams'.
We use matlab 7.0.0.19920 (R14) and simulink 6.0 (R14)
When we launch matlab this message appears:
Starting the SIT Server on port 6011
SIT Server started
Do you know what's the problem?
Thank in advance
Best Regards
(2,251 Views)
Hi, ingema,
this error is documented on the following KB:
http://digital.ni.com/public.nsf/allkb/272045B76849B7D9862571B5006A932C?OpenDocument
Hope it helps!
Saludos.
Jesús.
(2,244 Views)
