SIT Connection Manager - Data acquisition
Hello there. For some time, I have been trying to solve a problem connected with the use of the SIT Connection Manager.
I have linked a Matlab model file with the vi successfully, no errors, etc. The thing I am trying to do is to acquire two variables: X and Y and plot them onto a XY Graph.
The problem is, however, that the data flow from the matlab file is so quick, that when I acquire a set of data (x1 y1) it is immediately overwritten by  the next set  (x2 y2) and this goes on and on. In the result, I don’t get a plot on the XY Graph, I always get a point, which is constantly moving.
I tried to build a buffer (with shift registers, while loops, even queue blocks) and nothing works – either I have no data at all, or  just the first pair 😕
I tried mapping the X and Y from Matlab directly to a XY Graph, but that didn’t work, so now I mapped  them to a Indicators, and from there I tried to connect them further to build that buffer. I think that the problem is connected with the way the X and Y data is made available to connect – they are in a case structure, and I can’t access them both in the same place (vide pic). When I try to remove them from the case (by a simple wire to an e.g. indicator , they don’t get updated at all).
So… my question and help request is connected with the problem: how to buffer data coming out of a Matlab File so that I can plot them all in a XY Graph.
I contacted our regional NI Tech support, they gave me some advices, but they don’t seem to work. So while I replay them (the replay takes 3-4 days to come back) I’m trying to seek help here.
Thank you for the discussion.
(3,968 Views)
Hi!
Could you send the VI instead of screenshot? Would be easier to help.
Br,
Peter
(3,954 Views)
(3,944 Views)
I have checked your code. Please help me with answering these questions:
- Where do you write X and Y local variables? I can't find them.
- Why did you implement queue in the block diagram, what is the purpose of that? (right below the while loop.)
- As long as I see, you draw 10 elements in the XY graph but all of them has the same coordinates. Am I right?
br,
Peter
(3,940 Views)
Hey
To answer your questions:
-          X and Y as local variables are written in the case loop signed as SIT_Indicator_Cases  Ther are 3 cases: -1, 0, and 1 For the -1 condition, there is nothing (except two empty arrays that I have put in, but they are unwired). For the 0 condition, the X variable is available, and for 1, the Y variable is available. The funny thing is, that even though X and Y are in separate cases, if you link an indicator to them, they  both generate results. But if you take on the indicator outside the case loop – they don’t show anything, or just one of them show something, and the other is constantly 0. In the vi I tried to acquire X2 and Y2 which should be the same as X and Y in separate cases structures, but that doesn’t work as well 😕 So, I tried to attach local variables to X and Y – they are used in to separate solutions – in the while loop, where I tried to use shift registers, and under the while loop, where I tried to use queue blocks.
-          I tried to use another solution for creating the buffer in the hope of that this one will work – the one with the shift registers doesn’t so… it was just an another plan to get this problem working – it didn’t. As I saw it didn’t even acquire X and Y values, not to mention writing them into a queue.
-          Yes. I should get 10 different X and Y values – X and Y indicators show different values each second, or so, and in the while loop I get only 10 times the same value (sometimes the last 2 values are different, like the actual second value that was shown in the X and Y, but as that happens, actual values of X and Y is not second, not third even, but it’s like the 30-eth or so, it depends.
Generally creating a buffer is not complicated in normal cases, but hiere the values come from the Matlab and I think that’s the main reason it can’t be done I regular ways (with e.g. shift registers)
Thank you for your time and attention
Peter
(3,936 Views)
I am afraid there is problem with the basic structure. Let me translate your code into pseudo code, so you can identify why it gives 10 times the same value.
FOR
   X=GETX();
   Y=GETY();
   GRAPHX[]={};
   GRAPHY[]={};
   FOR i=0..10 DO
       GRAPHX[i]=X;
       GRAPHY[i]=Y;
WAIT(500); ENDFOR DRAW(GRAPHX,GRAPHY); ENDFOR
 So you set the X and Y once per FOR LOOP iteration, and write it into the graph ten times in the very same FOR LOOP iteration. X and Y will get new value only at next iteration.
Using QUEUEs is a good idea, but the way you implemented is not correct. The best way to start with it to check Example Finder in LabView help, end examine QUEUE structures like Producer/Consumer loops.
I hope It helped.
Peter
(3,932 Views)
We had to pause on this project for a while, I’m returning to it in a couple of days, so I’ll update this topic, if your solution helps 🙂 I’ll need to refresh my memories on queues in LabView however. Still, thanks 🙂
(3,855 Views)
