Hi Adnan,
Q) From your screenshot, it looks like you are using the Import Shared Library Wizard. Am I correct?
A) Yes you are correct from the screenshot I gave you
Q) If so, is there a particular reason as to why you do not want to use the SIT Connection Manager?
A) As we need the UDP functionality (to send and receive model data to multiple other systems) we originally planned on using SIT Connection Manager as suggested and our custom UDP blocks. Obviously that is the other issue and whilst SIT Connection Manager gives a block diagram it doesn't seem the easiest to modify to place LV UDP blocks and parsing sub-VIs etc into. Our thoughts were to import using the wizard and setup the functions as required with the LV UDP data communication blocks and parsing done around them. Would this be too tricky?
An easy solution would obviously be to pass the values back to a host and get that to send the data on, however we wish to run the model headless on the cRIO
Q) My next question involves using some of the models that are shipped with SIT. Have you tried the procedure with the sine wave example?
A) All models, including some basic test models we made, seem to work when using SIT connection manager. Haven't tried using import shared library (see above) to see if that gives a similar response
Thanks again,
Rich
