SIT and S-function based on mexw32 file
I am tring to build a simulink model which includes masked s-function.
According to Simulation Interface Toolkit help, original .c or .h files of the s-function have to be defined in nidll_vc.tmf tile.
Then how can I do that if the s-function was based on .mexw32 file? In particular the s-function is generated by AMESim software.
software version is:
LabVIEW and SIT 2009
Matlab R2008a
thanks in advance.
(3,192 Views)
Can you tell me which version of LabVIEW you're using as well as your pc configuration?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,138 Views)
