SIT - how to set the simulation stop time from Labview
Is it possible to set the simulation stop time (in Simulink) from Labview when using the SIT toolkit? If yes, how?
Alex
(3,382 Views)
Greetings!
   1)  You could change the simulation stop time in simulink. The process to do that is explained in p-10 of the following link -
    http://www.ni.com/pdf/manuals/370420b.pdf
   2) In LabVIEW you have simulation time vi, this returns the current simulation time. This value is useful if you terminate the simulation before the final time and you need to know the time at which the simulation terminated. This value is also useful if you want to generate a signal based upon the simulation time without using the Signal Generation functions.
There is no direct method to vary the simulation stop time in simulink from LabVIEW
Hope this helps. Good luck
Best regards
Avi Harjani
(3,363 Views)
