SMS Application - Hardware:GSM Modem & Software:LabView
any applications for this
Message 61 of 82
(4,678 Views)
Hi all
Please help me or explane.
I have modem SIEMENS MC-35i.
And I have the same problem.
I can to send SMS via Hyper Terminal.
But I can't to send SMS via LV.
I added the my VI.
Where is my error?
Best regards
Iskander
Message 62 of 82
(4,608 Views)
in write buffer 2,  the answer back from the modem do not show the OK,  in hyperterminal it is similar?
in write buffer 3 , the long  string start with a space, normal also in hyperterminal?
about the handshake in hyperterminal? similar?
Message 63 of 82
(4,591 Views)
I think your wait2 is not long enough....
Message 64 of 82
(4,587 Views)
Hi
Thanks for the answer and attention
I show new VI , where I have OK after every command
And this same message I sent to Hyper Terminal. The answer from Hyper Terminal the same OK
Regards
Iskander
Message 65 of 82
(4,583 Views)
Hi
All are working
I had error in the start with a space before  the message. I delete this spase.
Best regards
Iskander
Message 66 of 82
(4,561 Views)
Hi all
I have else question
I want to know the remain money on the account
From the mobile tel. I send command *111#.
How do I send command from modem mc-35i ?
The command *111# don't work
Best regards
Iskander
Message 67 of 82
(4,532 Views)
hi
try with a CR alone or CR LF at the end of the string
then my solution to remove the space worked!!  let me know using solved and kudos....
Message 68 of 82
(4,522 Views)
hi
Message 69 of 82
(4,522 Views)
Hi
Thanks for the help
I sent : *111# CR LF
But I don't see the answer from modem
Regards
Iskander
Message 70 of 82
(4,512 Views)
