SMS application with LABView by using handphone
I suppose to develop a system with sms application, could anybody share with me how to do it?
thank you very much...
Best Regard
Kelvin
(3,376 Views)
well, you should do some reading, put to point you in a direction:
Depending on what modem you use - I would recommend you'd connect a modem (or your cellular phone) to your computer and labview application; and learn and play with the Hayes command set first.
http://en.wikipedia.org/wiki/Hayes_command_set
and later try some SMS functions as described in a part here:
http://www.cellular.co.za/hayesat.htm
(3,362 Views)
Hi Kelvin,
I don't know what the application is like. But LabVIEW has the Short Message Services VIs to enable Mobile applications to programmatically send SMS messages from a phone-enabled Mobile target to other phone-enabled devices. Please check out the link below.
http://zone.ni.com/reference/en-XX/help/372508B-01/lvpdagsm/pda_sms/
Or you may use GSM SMS Toolkit for LabVIEW.
http://sine.ni.com/nilex/DisplayLinkAction.do?id=5174EXT
http://forums.ni.com/ni/board/message?board.id=170&requireLogin=False&thread.id=142443
(3,337 Views)
