SMS to multi user
Dear all, i was looking on how to send SMS using my PDA with the help of LabVIEW to more than one user at the same time.i.e;more than one recipient address
Message 1 of 13
(4,314 Views)
As far as i know SMS are transitted one at the time.
That stands for all the mobile phones too. Even if you select multiple numbers, the phone just sends the SMS one at the time.
Message 2 of 13
(4,309 Views)
thanks for your reply.ok if that is the operation of the mobile with multi recipient address then how to put more addresses on the LabVIEW to be sent the sms each one at a time.
Message 3 of 13
(4,287 Views)
I have not worked with a pda, only with GSM Modems.
I have a sub-vi called "Send  SMS" and it has two inputs, phone number and text. I just call this sub-vi many times.....
Message 4 of 13
(4,268 Views)
dear
how are u sending sms on mobile please tell me because i am working on same project
falgandha
Message 5 of 13
(4,263 Views)
dear all, first thanks for your reply.if i repeat the sms software on another case structure using another phone number, will this work.
Message 6 of 13
(4,255 Views)
dear. i have attached a JPG file for my software hoping it will be useful for you. if you have any problem please tell me.
Message 7 of 13
(4,254 Views)
Why not? If it works once, it should work as many times as you like.
Message 8 of 13
(4,240 Views)
With AT commands.
What hardware do you have?
Message 9 of 13
(4,239 Views)
dear all is there any other way to implement multi user sending sms on my pda using the LabVIEW except the same case structure
Message 10 of 13
(4,228 Views)
