SMTP of POP3 Mail error ! help me !
i want to use a  POP3 mail account to auto send my test report to some mailbox. And i try to use the labview7.0 example vi  named "E-Mail Notification.vi". But it seems no work. Because my pop3 mail account need username and password. But the example doesnot  request me to input the username  and password . How to do it realize my aim? Hope for help !
Message 1 of 9
(4,607 Views)
Hi
Best choice is download OpenG internet connectivity tools from this link:
http://www.openg.org/tiki/tiki-index.php?page=OpenG%20Internet%20Connectivity%20Tools&offset=&sort_m...
Also, if you need to autenticate only in POP3 ( to retrieve messages), download this example:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3EE1556A4E034080020E74861
Hope it helps.
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 2 of 9
(4,599 Views)
i have already the SMTP Toolkit of NI . And when i use it, it doesnot work.
Message 3 of 9
(4,591 Views)
Hi
Download OpenG smtp toolkit. there is a vi named " SMTP server login" .
You can learn how to send login comands ( AUTH LOGIN) and send that command using the vi from NI.
Bear in mind that your name and password are base64 coded, So, best choice is use OpenG smtp toolkit.
Hope it helps
Alipio
Message 4 of 9
(4,580 Views)
Hi All,
Do anybody know how to send an email message in plain text format only by Labview? Or, how to modify the SMTP to plain text message?
Thank you,
Smiley Sad
Message 5 of 9
(4,357 Views)
The SMTP E-mail VIs do not contain inputs for programmatically communicating with a POP3 mail server to retrieve email messages. However, the NI Developer Zone includes an example of POP Mail VIs (linked below) that you can use.
The SMTP E-mail VIs are available in the Full and Professional Development Systems of LabVIEW 7.0 and later and in the LabVIEW Internet Toolkit 5.0 or earlier.
I hope this helps!
Kurt
Applications Engineer
National Instruments UK & Ireland
Message 6 of 9
(4,329 Views)
Hi Apple James,
Quote from the KB link:
By default, LabVIEW sends plain text. For a server to use HTML to read an e-mail, the header must specify that this particular email is formatted using HTML. The header is created by a SubVI two levels down into the email VI. To send formatted email one must find the VI that writes the header and change the input to this VI from "text/plain" to "text/html".
Kurt
NIUK & Ireland
Message Edited by Kurt NI AE on 11-08-2006 03:31 AM
Message 7 of 9
(4,300 Views)
Hi Kurt,
1)  I would like to send out an email message, not receive.
2)  I would like to send a plain text email, not html email.
Thank you.
Smiley Sad
Message 8 of 9
(4,281 Views)
The SMTP VIs do send emails in text format. Are you unable to get them to work?
Sarah
Applications Engineer | National Instruments | UK & Ireland
Message 9 of 9
(4,214 Views)
