SMU4139 - value to memory
I want to load element       array into the cache of the pxie4139 smu card, so as to prevent a change in the measurement caused by eg. updating the windows.
Reading the table, V, into memory and reading from the card.
In the Vi, a loop is made, which in the case of an update will destroy the accuracy of the measurements
Will you help me?
(2,261 Views)
Dear pawel1989,
in general it is possible to trigger measurements on the PXIe-4139, and the measurements can be timed by hardware:
https://www.youtube.com/watch?v=aQe7pI_3jhY
http://static6.arrow.com/aropdfconversion/98e60262b9438e4ca1ac882d5a611503972e0e43/pdf.pdf
"The PXI platform is optimized for triggering and data streaming on the PXIe-4138/39 modules. The modules use the PXI chassis backplane to send and receive triggers and events, which simplifies programming and system wiring."
The following material is also worth reading:
http://zone.ni.com/reference/en-XX/help/370736U-01/ni_dc_power_supplies_help/4112_measureconfigtimin...
Best Regards,
NI Applications Engineering
(2,202 Views)
