SNMP TRAP
Hello.
Does anyone knows how to get SNMP TRAP's through labview?
(4,227 Views)
This, I believe, is the same as this discussion. If so, please keep the discussion to one thread so people know what's going on.
(4,209 Views)
not the same...the word SNMP is the same the qst is not.
(4,202 Views)
Hi Alvarion,
what do you mean with "get SNMP Traps"?
Mike
(4,198 Views)
It is possible when you work with SNMP to config a Trap manager that will manage all the change requests, you can listen to the traps while they are sent (by sinifing UDP).
For example if i have a tarp manager then every "SET Request" i will send i will see a trap sent from the SNMP Manager to the trap manger that will indicate that there is a change request.
Anyhow i found in the SNMP Toolkit something that helped me.
Thanks anyway!
(4,196 Views)
