SNMP implementation
What do you mean with that? then what would be the correct type for a signed integer? Anyway, as far as I know, the NTCIP 1201 Definitions shows the object as INTEGER (0...255) they not mention anything about signed or unsigned for that object
Message 51 of 53
(1,450 Views)
My code accepts the type Strings of INTEGER and UNSIGNEDINTEGER. Generally the MIB should give an indication whether they are treating the data as signed or unsigned. UNSIGNEDINTEGER is not a standard type as defined by SNMP but the PDU encoding (as per the standards) does make a distinction so I added it as a type so things can get encoded properly.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 52 of 53
(1,447 Views)
THANK YOU with the unsignedinteger type now it works just perfect!
Message 53 of 53
(1,440 Views)
