SP3485 used in labview
We have a design to use Modbus communication using the SP3485. I saw that there are some modbus samples in the community but mostly these are equipment integrated with the standard. We would like to know if Labview can be utilized to interface with the specific chip. Would also appreciate if there are specific example code that someone can share. I have attached mien which i adapted from a post here. Would also appreciate inputs on why I cannot read any registers.
Thank you.
(860 Views)
(859 Views)
