SPC Toolkit for LabVIEW - where is it in the labview (8.5) developer suite?
I started using SPC toolkit for a project in Labview 8.2.1, had no problem until I upgraded my system to labview 8.5.  It said something like:
    Some subvis are too old to be converted to 8.5.
I went to the Labview Developer suite CD album (labview 8.5), and couldn't find the SPC for LabVIEW, only for LabWindows / CVI.  Then I went to NI's website and tried to find more about the toolkit, it seems this one had disappeared into thin air, along with the Enterprise connectivity toolkit (or Enterprice toolkit).
Does anybody know if NI stopped developing / supporting the SPC toolkit? Or if NI included it into other toolkit or product?
-Joe
Message 1 of 12
(7,963 Views)
Hi Joe,
it could be that there are some vi´s from LV5. So i think if you save the vi´s which are to old to use with LV8.5 with 8.2.1 then it should work.
Mike
Message 2 of 12
(7,960 Views)
It is included with the DSC module in 8.5.
Message 3 of 12
(7,955 Views)
Got it!  Thanks!
-Joe
Message 4 of 12
(7,920 Views)
Hi
sorry for a silly question, but I tried to locate the LabVIEW DSC Module 8.5 in my Professional development environment and I cannot find it.
Would you please tell me which disk is it on?
thanks
Pawel
Message 5 of 12
(7,727 Views)
It doesn't come with the pro version. As mentioned, it comes with the DSC which is an option for the Developer Suite or you can buy it separately.
Message 6 of 12
(7,718 Views)
Hi Dennis
I am sorry for confusion, I have full Developer Suite, Professinal Development System, inside 11 CDs.
Which one contains DSC?
I know I have had it in the previus version in the toolkit CD, but it is gone now.
thanks
Pawel
Message 7 of 12
(7,699 Views)
If you have the labview 8.5x version CD suite, then the LabVIEW Datalogging and Supervisory Control Module is a separate CD, you can browse its folders or you can try the setup.exe, which should give you the option to install the SPC toolkit.  if you have labview 8.21 and below and it might be in a CD called Enterprise Connectivity toolkit or the Addon Toolkit.
-Joe
Message 8 of 12
(7,693 Views)
Hi Joe
The confusion goes deeper and deeper....
I do not have such a CD on my 8.5 release.
any thoughts?
cheers
Pawel
Message 9 of 12
(7,687 Views)
I don't know the software modules that comes with each labview option (basic, full, and pro), but you can get the module from NI, for a moderate fee.
convert from an older version to the 8.5x version won't work because some VIs were too old to be converted to the latest version.
-Joe
Message 10 of 12
(7,683 Views)
