SPECS FOR : PCI 7030/6040E
Can any one tell me if i can generate a 10,000 Hz Sine wave using PCI 7030/6040E RT series DAQ board?
I know the maximum sampling was listed as 500Ks/S. But i don't understand this notation.
Pls help me out.
Krithika
(2,542 Views)
Actually if you look at the specs, the output rate is what you want and the output is rated at 1Ms/s.
According to Nyquist, the minimum sampling rate required to reproduce a signal is twice the desired frequency. In your case, you would need a minimum of 20Ks/s to output a 10 Khz signal. Now, at only 20Ks/s, you're not going to have a signal that looks exactly like a sine wave. The higher the sample rate, the "purer" the sine wave output. Try a sample rate of 10x (100Ks/s). That's 1/10 the maximum of the board. Play around with the Simulate Signal Express VI to see the effects of different sample rates.
(2,534 Views)
