SPI Length
I have successfully managed to connect accelerometer adxl345 to Labview with Arduino with SPI(4-wire connection+3.3V+GND) and get the right values.I use wires with length 15cm each. I want to increase this length, but every time I add new wires the accererometer seems to stop working. To be more specific it is powered on but it gives no values. I have read that distance affects the SPI but can this be the problem when increasing the distance by only 15cm ?
(2,767 Views)
Increase distance = decrease speed of communication and add filtering to keep the signal as high as possible and as low as possible for the 1s and 0s
Benoit
(2,727 Views)
Dear besguin,
Thank you for your reply.
Wouldn’t the problem be the same if I connected the accelerometer via i2c?
(2,721 Views)
Yes and no...
do not twist your I2C wires and longer it is slower it is.
I suggest you to use oscilloscope to evaluate your wire.
Here I have over a meter of wire with I2C without issues at a 100K speed.
Benoit
(2,718 Views)
