SPI on LabVIEW
Help me understand SPI on LabVIEW. Is it possible to do universal application that could sent and read frames to any device? Or should it be dedicated to slave that I want communicate with? How can I do it for many slaves on 1 PCB?
(2,362 Views)
Hi JoT.
Check out the links below for some introductory informatin on using SPI in LabVIEW:
Understanding the SPI Bus with NI LabVIEW
https://www.ni.com/en/shop/labview/understanding-the-spi-bus-with-ni-labview.html
Using SPI with LabVIEW and the USB-8451
https://www.ni.com/en/support/documentation/supplemental/08/using-spi-with-labview-and-the-usb-8451....
For further questions on SPI, I would post your question in the correct board below to get proper eyes on your issue:
AUTOMOTIVE AND EMBEDDED NETWORKS
https://forums.ni.com/t5/Automotive-and-Embedded-Networks/bd-p/30
Jiwhan S.
Technical Support Engineer
(2,294 Views)
