SQL Fetch Recordset Data provides incomplete results
I am using the code below to return data from an SQL database. However, all of the elements in the variant array are blank except for the last column. Using "Database Variant to Data" doesn't help (everything but the last column is still blank). All of the columns are being correctly sent from "List Columns" to "Select Data". The SQL query is a simple "Select" statement that should return all of the data in the table. The SQL table is set up with all fields as text. Yes, there is data in the table. What else could be wrong?
I am using LabVIEW 2009 and the database connectivity toolkit and MS SQL Server 2005 Management Studio Express.
Message 1 of 19
(7,142 Views)
You can try just leaving the "Columns" input to the "Select Data" VI unwired.  It should return all columns then.  This will determine if there is something about the columns input that it doesn't like.  You should be getting a 2D array of variants.  Make sure that you check for your results in both dimensions.  "Database Variant to Data" does not work on arrays.  You must put it in For Loop to get your elements to convert properly.
Message 2 of 19
(7,123 Views)
Thanks, I tried both of those things and still no luck. I get the same results with the columns terminal unwired. The variant array itself is blank except for on the last column index which has the correct data. Any other ideas?
Message Edited by Willy2a on 12-18-2009 09:41 AM
Message 3 of 19
(7,116 Views)
Are you saying that the last column is in the correct index, but that there is nothing else being returned?
Message 4 of 19
(7,111 Views)
The variant array looks like this:
There are the correct number of rows and columns, but only the last column has data.
Message 5 of 19
(7,108 Views)
I am not sure what is wrong, and I never use those functions to do a query.  Are you just trying to get all data in the table?  If you are then do a standard query of "SELECT * FROM tablename".
Message 6 of 19
(7,101 Views)
I get the same result with the code below. Any other ideas? Some kind of incompatability between LabVIEW and this version of SQL Server? I need to get this working by early next week.
Message 7 of 19
(7,084 Views)
I've always had to put a ";" at the end of my queries.  I don't have Labview on this computer to look at my queries, but I can check tonight.
Message 8 of 19
(7,077 Views)
Hmmm. That didn't help either.
Message 9 of 19
(7,073 Views)
And have you repeated the query in SQL Server itself? If you don't have a copy of the full SQL Server, you can download a free copy of SQL Server Express from Microsoft. You could also link to a SQL Server database in Access and run a query from there. I don't use the NI toolkit but I always run new queries from SQL Server Express first.
Message 10 of 19
(7,067 Views)
