SQL Toolkit -- problem searching Date/Time field in Access
I have got an application where I need to query a database (Access) between
two dates (usually the same date, a couple of hours apart). I have set up
the date field within Access as a 'General Date' but can't seem to get the
right format on the SQL query. I am always getting some error. I enclose
the date with {}, '', [], and () (and anything else I can think of) and I
still get a problem. It is now to the point where I think it might be a
problem with SQL Toolkit and Access working together.
I tried making the Date field into a string field (instead of a Date field),
but I can't search between time (I can search between dates, but not date
and time i.e. MM/DD/YY 00:00:00).
Any ideas?
Message 1 of 19
(5,714 Views)
Try putting the date into the format #mm-dd-yy#. The "#" signs should be included.
Message 2 of 19
(5,712 Views)
I have had exactly the same issue.  I want to do an sql query.
between two date times ie.  perhaps the same date, but two different times.
I have tried using the following:  SELECT * FROM ValveMeritData WHERE MeritTestDateTime >= 2006-06-06 and
SELECT * FROM ValveMeritData WHERE MeritTestDateTime >= 2006\06\06.
The database format for datetime is 2006\06\06 13:45:32
Message 3 of 19
(5,544 Views)
neither of the above queries worked and so I
tried using the # signs as suggested above.  This didn't work either.
Any other possibilities?
Anyone tried this?SELECT * FROM ValveMeritData WHERE MeritTestDateTime >= 2006-06-06
Message 4 of 19
(5,542 Views)
Try enclosing your date/time in single tick marks like '2006-06-06' or '2006\06\06'. You don't mention the database that you are using but you should try all of your queries there before writing the LabVIEW code.
Message 5 of 19
(5,538 Views)
Sorry, the database type is Access.
I just tried the following query SELECT * FROM ValveMeritData WHERE MeritTestDateTime >= '2006/05/01 13:24:28'
and SELECT * FROM ValveMeritData WHERE MeritTestDateTime >= '2006/05/01'  (which gave a data mismatch error).
I am going to try the query in access now.  I had pretty good success with other types of queries, just writing them in
Labview and testing.
Any other suggestions?
Message 6 of 19
(5,535 Views)
Hello again.
Have any of you done these types of queries with Access successfully?  It would be helpful to know that
the correct syntax does exist if I can just find it..
cheers,
Message 7 of 19
(5,532 Views)
Hello again.  I have tested a query written in Access, and in Access it works and selects the appropriate records.
If i go to the Access SQL view, the WHERE portion of the query is shown below.
SELECT * FROM ValveMeritData WHERE (((ValveMeritData.MeritTestDateTime)>#5/2/2006 11:0:10#))
However, it returns no records when run in labview.  Can this be explained?
Message 8 of 19
(5,526 Views)
I use this ...WHERE (Some_date_column <= #2011-10-07 23:59:59#).
Message 9 of 19
(4,899 Views)
Message 10 of 19
(4,898 Views)
