SQL and MS Access, error 4149
Does anybody knows what an error 4149 means. it appears while trying to
make a SQL request to an ODBC database (access 97 format). The odbc
driver is 4.00.440302 and dates from 16.6.2000.
Actually the connection to the database seems to be ok, but when I'm sending
a SQL command the error appears.
(3,644 Views)
The NI KnowledgeBase (document # 0Z9DD9A1) has some info that might help you
sort this out:
http://digital.ni.com/public.nsf/websearch/28a4cd5f3390a642862564d0006acd8f
John Lum
(3,644 Views)
