SQL capable RT system
Are there means of communicating with an SQL Server from a real-time system like the cFP or cRIO?
I don't wish to stream huge amount of data to the server but simply to make queries to it in intervals of
several seconds. From what I read, the SQL Toolkit will not run under RT. I am looking for a solution
that does not require an extra PC between the RT system and the SQL server.
My RT target will be part of an industrial control system that should make desicions based on status
read back from the SQL.
/Stefan
Message Edited by Morgue on 03-12-2007 01:56 AM
(3,812 Views)
/Stefan
This one is a tricky one but I think the most successful approach albeit not the most simple one is to use a database that has a documented network protocol interface.
MySQL as far as I know has that and I even think there have been people trying to write an MySQL LabVIEW library that talks directly to the MySQL server through TCP/IP. As long as you do not want to do to complicated things with the database I think this should be doable with a library of a dozen or so VIs.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,640 Views)
