SQL database
when i fetch data from data base the values for coloumn true will fetch -1 and 0 for false i need exact data from the sql . Can u Please help me to sort this things out .
(1,657 Views)
(1,643 Views)
That is correct. A Boolean is defined as F=0 and T<>0. -1 <>0, thus True.
You just need to use the primitive 'Not equal to 0'
Qestit Systems
Certified-LabVIEW-Developer
(1,617 Views)
