SQL vi's using MySQL database?
Is it possible to use connect to a
MySQL data source with the SQL vi's?
I guess that might be more of a windows
question, but I'd like to know if anyone
has done that.
-H.
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,619 Views)
Yes, that should be possible.
You need the MySQL ODBC driver for Win95/WinNT.
Try this link
http://linux.ind.ntou.edu.tw/Linux/packages/MYSQL/download_myodbc.html
If you need more information please ask.
Rolf
(3,619 Views)
Yes it is possible.
You need to download the ODBC drivers from http://mysql.com, then build a connection string using the MySQL ODBC drivers 3.51.9 as your data source.
(3,619 Views)
