SQLite on myRIO 1900
I installed SQLite on myRIO 1900 by OPKG, following this guide https://forums.ni.com/t5/NI-Linux-Real-Time-Documents/Step-by-step-Install-Configure-a-Package-using.... As you can see on the image below, the installation was succesfull.
And this are all the library available to install on myRIO for SQLite, I don't know if I should install another one.
When I finish to install all the library that I need on my device, how I can call it on LabVIEW?
Message 1 of 13
(8,846 Views)
SQlite Library has been used on Linux RT RIOs.
Message 2 of 13
(8,810 Views)
Can I use it on cRIO too? Where do i download SQlite library?
Message 3 of 13
(8,788 Views)
Download with VI Package Manager.
Message 4 of 13
(8,782 Views)
Dr. Powell
This library made by you can works on linux real time? For example: as a datalogger implemented on cRIO
Message 5 of 13
(8,777 Views)
Yes.
Message 6 of 13
(8,773 Views)
Hi drjdpowell
I installed the sqlite lbrary created by you, but when I wanna run the examples labview says that an error has ocurred
Message 7 of 13
(8,752 Views)
What version did you install?   Can you upgrade to the latest version on LAVA (the Tools Network one is a bit old).  It doesn't require OpenG.  Alternately, you could just install OpenG via VIPM.
Message 8 of 13
(8,745 Views)
I installed SQlite 1.7.3.65 and VIPM hasn't the new version of this library so I don't know how to upgrade
Message 9 of 13
(8,725 Views)
And It send me a warnings
Message 10 of 13
(8,721 Views)
