SQLite on sbRIO9637
I want to create a DB using Dr. JD Powell´s SQLite API.
The program runs on my PC but not on the sbRIO9637. I noticed that there is no "libsqlite3.so" in /usr/lib/ on the sbrio.
What did I miss and where can I get this file?
Thank you in advance.
GM
(5,757 Views)
Hi GM,
it is a Third-Party Tool with Support on http://lavag.org/files/file/212-sqlite-labview/
You should post your question there.
As far as I can see the Tool is not meant for using on a sbRIO Target.
Hope this helps.
Best wishes
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(5,684 Views)
Accepted by GerdW
Hello Dennil,
Thank you for your reply.
I could use the library after installing sqlite3 on the sbRIO using opkg:
I connected the RIO to the Internet. The command "opkg install sqlite3" installed the required package.
Kind regards
GM_1
(5,676 Views)
GM_1
We have the same issue that you have solved, trying to install SQLite3 on our sbRIO 9026.  We've found several posts for similar issues, but nothing yet that describes the installation process.  If you can provide any links or additional details as to how you solved this, it would be greatly appreciated.
Thank you.
(4,912 Views)
Hello jrayeske
try
  1. opkg update (forced a package list update from NI.com)
  2. opkg install sqlite3
That solved my  problem when installing sqlite3
GCentral
CTD + CLD + Pythonista
(4,822 Views)
