SSH CMD session with timeout
Hi community,
Here is the problem I'm having.  I need to SSH into a remote system and execute a command that has a small possibility to hang forever, the command will return a JSON text payload that I parse for a response.
When the command hangs it blocks my whole system.  What I would like to do is execute the command with a window title and a parallel timer that will taskkill the window if it stays open for longer then timeout, so how do I do this?
I've tried:
-Using START "Title" [ssh command] but this opens a Window secondary to the main System Exec.vi window that I can't read the return from.
-Using the SSH package from Labview with the timeout option, but this seems to fail more often
Is there a good way to do what I am trying to accomplish?
Message 1 of 1
(594 Views)
