SSH sous Labview 2021 SP1
i am trying to communicate with my motor controler  with the SSH protocol,  Windows 10 64bits and Labview 2021 SP1 32bits.
i am trying to reproduce what i manage to do with the Windows Terminal as shown in the screenshot attached. ( snip paste in my code window as reference only)
it seems i reached the answer "STDIN open for ascii input"  reply.
but i do not manage to send to command or read an anwser  :  here for example with Motor[1].jogspeed  i am expecting a 64 bits number as an anwser.
do you have any suggestion for me to test ?
thank you
Emmanuel
(1,285 Views)
The problem with NI's current SSH solution is that it is a single transaction and then it is done.  What I did was use an open-source .NET library to handle an SSH session.  I then wrapped this library around a class.  It works quite well for me.
(1,229 Views)
hello,
thank you
sounds a bit more complicated than i tough and hoped;
anyway , do you have an example to share ?
TAHNK YOU
Emmanuel
(1,227 Views)
