SSH2 library not working on cRIO RT Linux
Good afternoon.
I am trying to get a file transfer function on my LabVIEW application to work.
When a log file requested to be transferred by the user from the cRIO to the Windows host I use the lib2ssh library and the Field Services LIB2SSH toolkit.
It works fine in the development environment. However, I keep getting a file 7 error in the executable that it cannot find the lib2sshlv.so file.
Searching the cRIO I find that all of the files needed are in /usr/lib folder.
I have tried changing the user and group on those files to lvuser and ni as well as chmod to 777.
Also before changing the user and group from administrator, I changed the chmod to 777.
None of this has worked.
I also made a copy of the files and moved them to the /home/lvuser/natinst/bin where the executable it.
Any help or suggestions would be appreciated.
Steven Howell
Controls and Instrumentation Engineer
Jacobs Technologies
NASA Johnson Space Center
Message 1 of 1
(216 Views)
