SSI Encoder Implementation
Hi guys,
Sorry if I sound ignorant/uneducated, I'm not completely familiar with LabVIEW functions.
I was wondering what the easiest way to implement a rotary SSI encoder would be. The encoder would communicate with LabVIEW to measure the angular position of a motor, and also be used to move the motor in sinusoidal motion.
Thanks.
(3,549 Views)
One of the ways you can implement a SSI encoder would be using a FPGA with digital lines. This FPGA works well with Labview. I am attaching a link that might help you with your problem measuring the angular position.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIBYSA2&l=en-US
Regard.
Michael Pinzas
(3,458 Views)
Just to add a bit onto this, this requires a purchase of an FPGA board, that you can see here: https://www.ni.com/en-us/shop/category/multifunction-io.html?productId=118690, and using the LabVIEW FPGA Module, both of these in addition to the LabVIEW installation that you already have.
C. Weeks
Product Support Engineer
NI
(3,450 Views)
