SSI USB
I have used the supplied libraries with LabVIEW 8.5.
Ihave not used more than one card in a single PC. Deva's techinical support is good, give them a call.
Message 11 of 25
(5,693 Views)
Does anyone know how to get a PXI bus SSI interface board? It seems that Deva doesn't provide products on PXI platform.
And why doesn't NI provide products like SSI interface boards? As I know there does exist lots of needs about this.
Message 12 of 25
(5,597 Views)
Hi Leon,
Unfortunately, due to the number of protocols available, it is extremeley difficult to produce dedicated plug in  interface boards for all available protocols. We make every effort and take much debate in the development of plug in boards for various protocols, but the range of platforms on which we can produce makes it even more difficult. Whilst there is unfortunately no plugin board vailable on PXI at this moment in time, future developments could make this a possibility.
There is one plausable route that you could take however is by looking into using FPGA perhaps? Could this be a possibility for you?
Rob L
NI Applications Engineer
UK & Ireland
It only takes a click to rate this message 😉
Message 13 of 25
(5,570 Views)
ok, i'm confused.  if i have a sensor with ssi outputs and i want bring the data into labview through a usb port can i use the  NI-USB-8451?
Message 14 of 25
(5,476 Views)
The USB-8451 will allow you to utilize SPI and I2C interface protocols within LabVIEW, but this doesn't natively support SSI
All the best,
Message 15 of 25
(5,463 Views)
so what is my best option to take a ssi signal into labview via usb?  i have a ssi to serial converter box but i like the portability of usb.
Message 16 of 25
(5,453 Views)
I was unable to find an SSI USB device. I ended up using a PCI card (obviously no good for a laptop!).
Message 17 of 25
(5,449 Views)
I'm afraid that if you wish to communicate via SSI then USB isn't an option for you and PCI/PXI form factor is required with FPGA to program the SSI logic.
All the best,
Message 18 of 25
(5,447 Views)
BEI Industrial Encoders has a couple of products that convert SSI encoder signal to USB.  I haven't used them so can't speak to how well they work, as I am just starting this inverstigation myself.
Message 19 of 25
(5,304 Views)
You may want to consider using a stand-alone SSI Interface Controller. Here's one that I found that works nicely.
http://ssi.xtreemhost.com
Message 20 of 25
(5,266 Views)
