STFT Spectrogram - 50% Overlap
hello Dan
Could you tell me in wich training you are ?
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 21 of 36
(4,119 Views)
Hello...
Sorry, I did not understand your question, "which training?"
Dan07
Message Edited by dan07 on 01-30-2009 08:53 AM
Message 22 of 36
(4,112 Views)
sorry,
what is tou study level, technician, engineer, at school or at work
best regards
Message 23 of 36
(4,101 Views)
I am a PhD student on medical sciences, but I have a great interest in data analysis. I am improving my Labview skill, but sometimes some basic math concepts are missed and I don't know how to solve the problem.
Concerning my answer about how to match the 34 values for mean and stdvs and the 34 spectrogram rows (after the removal of first and last row), may I accept as true that the first mean and stdv value will correspond to the first row of the spectrogram? In other words, the data used to generate the first row of spectrogram is the same that used for first mean and stdv results?
Thanks for your great attention
Dan07
Message 24 of 36
(4,095 Views)
I made a mistake on the last message:
"Concerning my question" its the correct.... I wrote "Concerning my answer"
Dan07
Message 25 of 36
(4,090 Views)
isn't it a little bit dangerous for patients ? :smileyvery-happy:
here the explanation see on attached jpeg,
1 is window used by stft
2 window used with for loop
That is why you have 2 more rows in final array , the first and the last ...
See you
Tinnitus
Message 26 of 36
(4,081 Views)
Thanks for explanation. So, I can remove the first and last rows of the spectrogram, and match the 34 rows of the spectrogram with the 34 means and stdvs values: first row of spectrogram matchs with first mean value, second row of spectrogram matchs with second mean value..... all right?
Dan07
Message 27 of 36
(4,073 Views)
yes...
Message 28 of 36
(4,069 Views)
Hello...
After all your help, the code its working properly now... the only doubt that I still have concerns the huge difference between the absolute values showed by specgram (matlab) and spectrogram (labview). The normalized values (%) are exactly the same, but the absolute values returned by specgram (matlab) are much greater (40x greater, or sometimes 200x greater). Do you have a idea about what might be happening?
Dan07
Message 29 of 36
(4,041 Views)
Accepted by topic author dan07
hello Dan,
did you compare graphic or array values .
did you compare right after specgram function ?  because if i remember well there was a CxC* in matlab code
did you implement same in labview code ? conjugate block is in numeric->complex->...
tell if this helps
Tinnitus
Message 30 of 36
(4,032 Views)
