STL file export from LabView
We have a 3D array of vertices (x,y,z) (cloud of points). Is there a way to exsport an STL file based on the 3D array?
We tried using this VI:  http://forums.ni.com/t5/LabVIEW/3d-model-exprot-from-labview/m-p/2831766/highlight/true#M827698 , but it created a broken binary STL file.
Thank you
(5,765 Views)
STL is a mesh format, meaning that your vertices must be organized in triangular surfaces (3 vertices per surface) before being able to export them. Going from cloud of points to surface is a tricky thing. The easiest thing I can recommend is to export your points in a format compatible with Meshlab (www.meshlab.org) and use Meshlab to convert your cloud of points into a mesh. Then export from meshlab into a .STL file.
You can use the 30-day free trial Haro3D library (download using VIPM) to export the cloud of points to a .XYZ or .PLY file.
And join the 3D Vision group if you are interested.
Good luck
Marc Dubois
(5,726 Views)
You can see it in my example.  It will generate both formats ply and stl files.
(4,865 Views)
