STM meta data not defined
Server returning error 1 - meta data not defined
It is not clear to me how to define the meta data used in STM.  I have created an array of clusters that contain a string.  I have named the clusters.  The STM VIs returns an error concerning the meta data not being defined (Figure 1).  Figure 2 shows the server code that generates the error and figure 3 show the client code.  To start, I am trying to pass a simple string but I would like to pass arrays of data once this is working.
Client and server both running LabVIEW 2012 (32-bit) version on Windows 7.
STM package:  stm_1.0.32.zip (not sure this is correct version.  Example programs use VIs with different names.  Unable to run examples because I don't have the VIs used in the examples.)
Application:  Stream data from embedded PC to UI using ethernet connection.
White Papers: LabView Simple Messaging Reference Library (STM)
                        Command-based Communication Using Simple TCP/IP Messaging
Client Error
                                                              Figure 1 - Error
Server Diagram
        Figure 2 - Server Diagram
Client Diagram
        Figure 3 - Client Diagram
(4,067 Views)
That is a pretty old version.  Download the latest version (2.0.2.1).  The can be found here:http://zone.ni.com/devzone/cda/epd/p/id/2739.  If you use VI Package Manager, use the VIP file.
(4,061 Views)
Have you double checked to make sure that you do in fact have a TCP connection established (ie, your TCP listen block is not timing out and passing on an error)?
I would also recommend upgrading to the newest version of the STM pallette.
James K.
(4,035 Views)
I was able to load the latest version of STM onto my machine.  I am now clear on how the Meta data works.  I will continue on.
Thanks for the help.
(4,029 Views)
Just so you know, there's a board specifically for the STM.  That would be a good place to ask for improvements or better clarifications.
http://forums.ni.com/t5/Components/Simple-TCP-Messaging-STM/td-p/583438
(4,027 Views)
