STUDENT T TEST
Anyone with a LabVIEW implementation of the Excel "test.student" statistical function ?
See attached Excel example.
I need to use the "unilateral" argument for the distribution as well as the type 2 (sample with equal variances), unlike in the Excel original example.
The computed value I'm after is also known as the "p value".
I guess this will seem pretty basic to many, but I have very little statistics background, so help is very welcome.
LabView 8.2, 8.6 or 10
Message 1 of 13
(8,082 Views)
Have a look at the Hypothesis VIs under the Mathematics pallete.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 2 of 13
(8,062 Views)
Message 3 of 13
(8,061 Views)
Accepted by topic author petergod
The T test VI in the Hypothesis testing palette is for a single sample, but located inside that VI is the Student distribution CDF subVI which is very useful to construct the two sample test.  Here is an example for the one-tailed test for equal variances as well as pairwise test, you'll have to look up the formulas in any standard text.  It matches the Excel result, I always worry about using N or N-1 in various locations.
For the two-tailed result, just double the p-value.
Message 4 of 13
(8,050 Views)
Thanks for looking. I found that already but was lloking for a more complete implementation. Darin.K did a great job on this one - see rest of the thread. CU
Message 5 of 13
(8,019 Views)
Great, this is fast & efficient :-) Just revised it a little bit to completely mimic (I hope) the Excel 2003 implementation I'm after. Great help CU
Message 6 of 13
(8,015 Views)
Well in fact there is an issue, depending on the datasets. Either the pvalue is exactly the one returned by Excel, or it is completely different. I see no obvious reason. Any idea what's going on ? See attached XL file with examples & the same in LV 8.20
Message 7 of 13
(7,970 Views)
Seem to be missing attachments.
Message 8 of 13
(7,962 Views)
for some reason, attachements do not work today!? New trial
Message 9 of 13
(7,955 Views)
If you preview the message, the attachments will be stripped.  Otherwise, just post the data as text in a message along with the Excel result.
Message 10 of 13
(7,938 Views)
