SUB-VI showing the options made in the MAIN-VI.
Similar to previous post on SUB VI used in Main VI
Download this .zip and extract all files to a folder, used LabVIEW v9.0f2.
I want to use Light Show as a Sub VI to Furnace Cycle MAIN1 (Front Panel) - I need to use this Sub VI (sub of one light control) with many light on the Furnace Cycle MAIN1 front panel.  In the light show VI, I am using an enumerated control to simulate inputs from a future PLC and the boolean switch simulates power is applied to that PLC.  The light color is white when the PLC is not active or does not have an output to the light.  The light show VI is written in the form of a state machine.  I need to to have a stop boolean control to stop the Furnace Cycle MAIN1 program and all the sub vi's. Any help would be appreciated.  I am open for other code processes like arrays etc. to accomplish the same results.
Message 21 of 21
(469 Views)
