SV Assistant Memory Issue
Been playing around with the Sound and Vibration Assistant - but have come up against what appears to be a huge wall.  Once I've taken data, the SV Assistant does not allow me to do much of anything else.  I've come up against the following errors:
"Not enought memory to complete this operation"
"Labview: Memory is Full"
which then leads to:
"File I/O error - An error occured while reading from the file..."
because when the memory error occurs, the SV Assistant freezes, and then corrupts the project file.
Am I missing something here?  Seems that this product is not meeting the standard I expect from NI.
John Skurka
Staff Engineer - NVH
BorgWarner MorseTEC
(3,846 Views)
What's the size of the file you're loading?
I've never used S&V Assistant, but (like you apparently) I expect serious work from NI so given the error message you're reporting, I assume you're doing some extreme use of data.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,843 Views)
The file was recorded using the SV Assistant into a LOG file.  The measurement is a typical NVH style measurement, consisting of a 60s runup.  Data is being sampled at 50khz.
John Skurka
BorgWarner MorseTEC
(3,841 Views)
3M samples... What datatype is it? I mean how many bytes per sample? And how many channels?
If you have more than one channel and to try to graph this, it could be a little big...
Epictetus
Antoine Chalons
(3,837 Views)
That shouldn't matter.  I've taken similar data with other specialized NVH Software (HEADAcoustics) that samples at 48k, two ears and a tacho without issue, for even longer ramps (90s).
It appears that for whatever reason, NI is reading this all into RAM - I thought that was the purpose of the LOG file.  Write data to a file, and work with it from there.
John Skurka
BorgWarner MorseTEC
(3,835 Views)
Hmmm I understand your frustration... I dont' use S&V Assistant so I don't know if it tries to load the whole set of data, I don't know either is there is a way to split the LOG file into pieces or to tell S&V Assitant to load only a part of it.
Sorry I can't help more than this.
Epictetus
Antoine Chalons
(3,833 Views)
