SV aures
hi, i would like to use the SV aure tonality algorithm to analyze a wav file.
what kind of input should i be connecting?
(3,382 Views)
If you look at the help file for this particular function, it explains the type of input needed. Below is the link to the help file explanation for this function:
http://zone.ni.com/reference/en-XX/help/372416E-01/sndvibtk/aures_tonality/
How are you getting the wav file? Are you acquiring the waveform using a DAQ device? You can use the Read Waveform from File.vi to read the waveform and connect the waveform output to the SV saures. Try this out and see if it works.
Alan
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
(3,316 Views)
i am recording a 10 secs wav file using NI 9234 and it is saved into my disk. after which i would like to process it using the tonality algo.
(3,295 Views)
