SYSCFG operations interfere with COUNTER channel measurements
LV2013, LVRT2013, Win7, PXI-8196
I have a system where the host program communicates (TCP) with a program on the PXI.
The PXI measures all manner of channels and reports to the host at 10 Hz.
The CPU on the PXI normally runs at 5-7% utilization.
HOWEVER
it is apparently being overburdened periodically by an operation, that I instigate from the host, every 10 seconds.
Here is a 3-minute data record. I now have a switch where I turn off the 10-sec status request.
I turned it off about 45 sec before this picture was taken, and you can see the disruptions at 10-sec intervals, which stop about -00:00:45.
Here is the code that executes on the PXI when a status request comes in:
I'm using the SYSCFG operations to obtain data about CPU loads, and internal temperatures.
So, am I doing something wrong?  The PXI is running a real-time OS (PharLap, I think), but this is hardly behavior I would expect from an RTOS.
I have ALSO seen the same thing in another instance - when conducting a test of high-volume data communication between the PXI and the host, I am measuring the data rate.  That data rate takes a dive every 10 seconds if the status request is there, and stays stable if the status request is not there.
Any ideas?
Steve Bird
Culverson.com
LinkedIn
(3,727 Views)
Here is the code that measures the frequency (on the PXI box).
It is called at 10 Hz (barring disruption).
There is a buffer for counter readings, and I subtract the oldest from the newest and scale that into frequency.
Steve Bird
Culverson.com
LinkedIn
(3,715 Views)
Here is a pic of the data soon after PXI startup (reboot):
The yellow signal is an analog temperature measurement.
that signal drives a frequency OUTPUT, which I am then measuring with a counter INPUT.
Notice the good agreement up to a point, and then the disruptions start (I didn't flip a switch here).
After 60 sec of disruptions getting larger and larger, the base signal starts to diverge.
Steve Bird
Culverson.com
LinkedIn
(3,710 Views)
Disabling the TEMP reading part gets rid of the every-10-sec disruptions.
Steve Bird
Culverson.com
LinkedIn
(3,695 Views)
The discrepanacy between the analog reading and the frequency reading IS caused by my PXI box's air filters being dirty - the CPU was apparently protecting itself by slowing down, and so the counter operation wasn't consistent.  That's why data was good for a while after a reboot.
You can probably tell where I took the filter cover off:
Steve Bird
Culverson.com
LinkedIn
(3,693 Views)
OK, cleaning the air filters changes the nature of the disruptions.
They're not as long-lasting, but somtimes there are multiple ones now.
CONCLUSIONS:
1... Keeping the AIR FILTERS clean is important.  I have tripped over that before.
2... The SYSTEM HARDWARE - CURRENT TEMP function is faulty somehow - it apparently uses a LOT more CPU than expected.
Steve Bird
Culverson.com
LinkedIn
(3,690 Views)
