Same name for different controls
How LabView resolves name conflict when  two indicators or controls  are with same labels .In C declaring different variables is impossible,
as this will throw the compiler error?
(4,422 Views)
I think how LabVIEW resolves the conflict is not important if you stop thinking of controls & indicators as variables.  Use the wire as the variable and there's no confusion.  I believe, however, that how LabVIEW resolves the conflict is indeterminate.
You shouldn't use the duplicate labels, anyway, use the object's caption instead.
Jim
(4,410 Views)
With the exception of the Invoke Node Set control value method, LV does not depend on the controls name. It makes it hard for the developer when they have the same name but LV really does not care.
BTW: The previous post about not thinking about controls and indicators as variables is important when trying to understand how LV works.
"The wires are the variables."
If you still are using ideas from C that depend on you having names for each variable, then drop a free lable on thediagram near the wire to help you out. Eventually (if you are like me) you'll not need teh lables anymore.
Ben
(4,384 Views)
Whatever you call a variable, be it the wire or the control, LabVIEW should not allow duplicate labels.  When you copy a control and paste a duplicate, it adds a 2 after the label.  So even Labview won't duplicate the label.  Why would it allow a user to do so.  I know that Labview doesn't care, but lets make this a bit more user friendly shall we.  Users use labels and refer to labels (or captions) to identify variables.  Its a throwback to text based programming, but the notion will not ever go away.  I've been using LV for over 10 years and I sitll rely on labels and captions to identify variables.  A wire is variable, a control is variable, an indicator is variable.  They all can have their values changed.  Therefore they are all variables by definition.
- tbob
Inventor of the WORM Global
(4,364 Views)
Why?
Not being in the design meeting we can only specualte but I would think "Why not?" It does not hurt anything, besides, it is a bit of an eye-opener for text coders to get them thinking that there is something differnet about LV.
Done speculating.
Ben
PS: I avoid duplicate names.
(4,354 Views)
@Ben wrote:
Why?
To help the user avoid making a blunder.
@Ben wrote:
"Why not?"
I need all the help I can get.
PS:  I don't use duplicate names either, but I have inherited some code where a duplicate name was used.  Very confusing.  There was a property node.  Which control did it belong to?  "Numeric" or "Numeric"?  Of course it was easy to find by right clicking and selecting Find Control.  But this should not be allowed.I don't want to have to think more than I already have to.  I'm lazy.
- tbob
(4,337 Views)
Each object has its own reference.  Whether it is a wire or a control.
So if two objects have the same name (ie two controls called Numeric), they have their own unique reference designator.  That is how LabVIEW keeps track of each object.
(4,332 Views)
