Same vi, different behavior based on build spec?
Ya you're probably right.  If I do end up diving in and spending the time now, it wouldn't be only to solve this problem, but any that might come later as well.  I have seen an example in the past where a guy coded something to work with serial;, and through the use of OOP, was able to convert over to ethernet by small object changes (which is what I though VISA was supposed to do, but another subject), which I thought intriguing.  Thanks for the link...
David J.
Message 11 of 11
(476 Views)
