Sample Data Read Timing Issue
Hi Engineers,
Currently I am facing one issue with my Analog card. In my project I have some Analog Input Channels.
To acquire the data from these Analog Channels I have PXI-RT system with PXI-6225, PXI-6255 cards.
If I configure my card with number of samples 1 and numbers of sample to read 1, I got the result in 2 Sec, but if I increase these samples more then 1 (No of samples=Samples to read) I got the result in 1 Sec.
Ideally if the number of samples and samples to read values are same the result output time should be 1 Sec.
I am confused here why I am getting the update result in 2 Sec with 1 sample. If someone know the reason or aware with the same issue please suggest me the changes.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 1 of 1
(2,497 Views)
