Sample depth in a strip chart display
I am using LabView 2012 and use the strip chart display to visualize parameters over test campaigns that take several days with 10's of thousands of samples.
While the strip continues to display the parameters, the maximum sample depth (for the X-axis scroll bar) I have currently managed to achieve is 1024 samples.
Is it possible in a strip chart to increase the sample depth above 1024 samples ?.
(2,575 Views)
Hi IanLuck,
Just right-click the chart, select Chart History Length, and then specify the number of data points you want to store in buffer.
And here is some (interesting) facts about Chart History Length
http://zone.ni.com/reference/en-XX/help/371361K-01/lvdialog/chart_history_length_db/
Enjoy
Ee Lim
See that button on the left side of this post...
If you feel my post is helpful, all you need is just (at most) 2 seconds to click that button, to show your appreciation. Thank you~~
(2,572 Views)
Thanks.
(2,554 Views)
