Sampling Serial Port Data
I am sampling data coming in via the serial port. The data is updated every second Displaying the one second data is fine, however I only want to store a record every fifth minute, how do I accomplish this without storing all the one second data?
(3,653 Views)
Use the Elaspsed Time Express VI to determine when 5 minutes have passed.  Put the code where you are storing the data inside a case structure that is wired to the Time Elapsed? output of the Express VI.
(3,645 Views)
Thank you for your response. How would this solution address data in the serial port buffer: that is, how do I know I am recording data received at the five minute interval verses recording data that happens to be queued in the buffer and was received earlier than the five minute interval?
(3,627 Views)
MacKensie,
You would read the buffer much more often than every five minutes. Read the port every second when the data is received. Put the data in a shift register or other buffer. Keep only as much data as you will want to display or save and discard the older data.  This is called a circular buffer.
If you only want to save the most recent data received, just keep only one point in the shift register.  When the 5 minute time has elapsed, save the point in the shift register, which should be the most recent point.
Lynn
(3,623 Views)
I said put the code where you store the value inside the case structure.  I did not say put the serial port read inside the case structure.  As Lynn said, you are constantly reading, only storing the value when the 5 minutes have elapsed.
(3,620 Views)
Thank you to both of you. I appreciate the support.
(3,613 Views)
