Save Channel data in tdms with along with Time
hi guys,
I need to save  a  BUS communication Protocol in TDMS  format. The different data say voltage ,current and bus signals are generated at  specific time intervals.
Whts an elegant method to save the Time Information( at which the specific signal say Voltage1[10000] or  BusConnect_Bool[10000], or ActivMode_U32[10000] )  along with the  Channel.
The channel is an Array of these values. I need the specific time for each specific element of the array, and every array.
The individual  signals are generated  at different  times eg voltage1 is measured at  t1, and  BusConnect_Bool  at t2.
the whole Dut test is also cyclic . thats why  10000 values.
regards,
Akshay
(3,004 Views)
Assuming a constant rate for each element of your array, I would use the data to build a waveform and then use Get Waveform Time Array to get an array of timestamps that you can then save to your TDMS file.
GCentral
(2,986 Views)
