Save Complete project for Distribution
I have a project which runs a top level vi. This vi calls a number of other vi's, dependancies, dll libraries, 'c' wrappers etc which are located in different windows folder locations on the source PC.
I would like save the whole project (including all of the other vi's, dependancies, dll libraries, 'c' wrappers etc) in order that the project can be run on another PC with Labview. (ie not a runtime application).
How do I do this please?
Please be kind on me I am a beginner in Labview.
Daniel
(5,495 Views)
Hello nevica,
You can build a source distribution.
https://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/build_source_distrib/
Regards
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(5,481 Views)
Ok, I have selected:
Build Specifications/ packed library. And then I am moving over the .vi that I want in the saved library.
1. It doesn't allow me to save any .vis to the top level library and gives an error.
Also, My actual project contains a number of dependencies. I need to save these in the library as well for the saved package to work on another PC running Labview.
Here is a snapshot of my project showing dependencies.
(5,474 Views)
As Sabri mentioned above, you should be building a "Source Distribution".
Corey Rotunno
(5,461 Views)
Ok, Thanks Cory.
So my next question is:
What about all the dependent files to make the top level .vi run (See my screenshot above). How do I save these? The dependicies are needed for the top level .vi to run on a second PC. Whout them Labview will return an error saying a package is not present.
(5,455 Views)
Whatever is statically linked within your top level.vi hierarchy should be included automatically.
For dynamically loaded files (e.g. DLLs), you have to include them manually ("Always included" on the source files section of the build spec) on your screenshot
(5,449 Views)
